Cloning issue takes long time
Jordi Federico April 23, 2019
When I am cloning an issue, sometimes takes very long aprox 20-30 sec.
I am monitoring the system and all seems ok.
Does anyone knows why ? Any workaround?
The only thing I have seen is, that if the issue has some worklogs, this takes longer.
Jordi
Claude Kilchherr April 23, 2019
custom fields?
do you mean, how many we have in our intance?
maybe plugin related? .. check for available plugin update
all plugins updated :/
How long does it take for you to clone some issue? (with worklogs included and without attachments)
i dont think the number is a KPI - can imagine that one field can cause such a high response time - always depends on the field and what are you doing with it.
maybe it will help if you can detect recent changes to custom fields that have been made since the problem was noticed.
Like • Jordi Federico likes this
some seconds with worklog and without no diff - do you use threaded comments plugin? do you use worklogPro plugin?
Jordi Federico April 24, 2019
How big is your instance?
I have actually 3 copies of mine in different VM, (for development, test and production ) and all the same...
I am not using these plugins, but might be... I use latest 7.13.2 server version.
Register now
