Cloning issues
Katherine B
Is there a way when cloning issues to also clone the watchers even though they have no action on the issue just a watchers on the state of the issue?
Katherine B
Thank you - will look into this.
Boris Georgiev [Appfire]
April 15, 2014
Seems not possible with the JIRA clone feature due to https://jira.atlassian.com/browse/JRA-28038
However you might be able to achieve that using an add-on like this one https://marketplace.atlassian.com/plugins/org.swift.jira.clone-plusand the only downside is that it is paid :)
Also you can write a listener with script runner that will fire on createIssue event and check if the issue is cloned and copy all the watchers from the original issue.
