Close issues automatically after a string is set on a comment?
Bruna Griebeler
November 18, 2015
On Jira, Is there a way to close issues automatically after a string is set on a comment?
Using JQL we can use bulk change - transition, but how can we automatize that?
Nic Brough -Adaptavist-
November 18, 2015
You need a little code to do that - a listener that can listen for issue updated and issue commented events, scan them for the string you want to trigger the change and then push the issue through the "close" transition.  I'd use the script runner to do that.
