Close resolved issues after a certain time automatically
Niek Neuij
Dear Sir/Madam,
Does anyone know how to close a resolved issue automatically after a certain time?
It would come in handy for our JIRA project we're doing.
Deleted user November 6, 2015
Try the SR Escalation Services, it works pretty well and setup is straightforward.
Jeff Louwerse
November 6, 2015
Hard to be explicit as there are many ways to ski this cat.
You can write some external script (say in PHP) to to make a REST call  to pull the issues you want to close (you can write you own JQL query to be exactly as you want it) .. loop though the issues and make REST calls to close them.  At least i think you can transition an issue via REST.
If you have scriptrunner or are familiar with writing services, this could be done there (that is where I do it).  The concept is the same.
Nic Brough -Adaptavist-
November 6, 2015
Also the automation addon is worth a shot. Jeff - you're right about REST, you can use it to push issues through transitions.
Bob Swift
November 6, 2015
Using JIRA Command Line Interface (CLI), you can use something like the following in your favorite job scheduler:
jira --action runFromIssueList --jql "status = resolved AND resolutiondate < -1w" --common "--action transitionIssue --issue @issue@ --transition \"Close Issue\" "
