Has anyone seen this before? I have an issue that when looking at the history (attached) shows it moving through the workflow to closed BUT, when I run a query of issues in the project it is showing as reopened though it never has been?
Mmm, sounds like the index might be broken. Could you try a quick edit on it - that should force a re-index
Unfortunately, no luck. Re-indexed and also ran the integrity checker for Workflow and it's still appearing
Thanks Nic - It didn't appear to work at first but now it is. Strange but good...
Renjith -
Here is the query. A little more info - this was noticed as the closed issue was showing up on a rapid board as reopened. This is the rapid board query - project in ("Creative Services", "Mobile Apps/Recommendation UX") AND (fixVersion in unreleasedVersions() OR fixVersion is EMPTY) and assignee in (bcooley, nnuss, okhan, jthomas) ORDER BY Rank ASC
Can you post the query that you have used?
Register now
