Code wanted for default value for calculated field
George Carvill
June 6, 2014
I'm dumb and can't figure this out.
I have a custom calculated text fiedl. All I want is for it to display the value of another field.
How do I write the code in the 'Description' field to make that happen?
George Carvill
June 20, 2014
I did make it work using the field index number, etc. But the field I wanted is the 'Sprint' field and the value I got was the index number of the sprint. Oh, well.
Nic Brough -Adaptavist-
June 6, 2014
How are you doing the "custom calculated text field"? With the script runner, a plugin or something else? As it's a calculated field, I'm not sure why you're looking at the default value as the default value won't matter if you override any entered data with a calculation.
Whatever you answer, the response is going to be roughly issue.getCustomFieldValue(field), but it will vary depending on how you want to do it.
George Carvill
June 6, 2014
Good catch. I didn't mean "Default" but "Description." I fixed that.
I'm talking about a custom "Calculated Text Field" which is described on the page where I select the new custome field type like this:
A calculated tex field. The formula is stored in the field description, inside an html comment.
George Carvill
June 6, 2014
I'm trying to put in a screen shot:
June 6, 2014
Ok, before you do, a "calaculated text field" is not a standard function, it's being provided by a plugin somewhere, and don't know which one does it. I'm only really familiar with the hard-coded ones I've written, and the script runner, so I kind of need to know which plugin it is so I can skim the docs (I know roughly what needs doing in Jira terms, but not what the plugin needs from us)
George Carvill
June 8, 2014
This is what I am trying to do:
https://innovalog.atlassian.net/wiki/display/JMCF/JIRA+Misc+Custom+Fields#JIRAMiscCustomFields-calculatedtextfield
But this doesn't work:
<!-- @@Formula: issue.get("10300") -->
