I'm getting "CodeCache is full. Compiler has been disabled" messages in the log.
I've read https://confluence.atlassian.com/pages/viewpage.action?pageId=314447083 and http://blogs.atlassian.com/2012/05/codecache-is-full-compiler-has-been-disabled/ -XX:+UseCodeCacheFlushing I still get these errors.
Any Idea what is causing such a huge amount of code?
Could it be the ScriptRunner? Isn't that continuously compiling groovy?
I don't know who is responsible for the code cache usage, but I raised the code cache to 256 MB and didn't have this errors anymore. Just add -XX:ReservedCodeCacheSize=256m to the JVM_REQUIRED_ARGS within your setenv.sh file.
Additionally I wrote a Script Runner service which logs the Code Cache Size to enable me to see the history:
log.info "Code Cache Usage: ${sun.management.ManagementFactory.getMemoryPoolMXBeans().find{it.getName()=='Code Cache'}.getUsage()}"
Maybe you want to reduce the ReservedCodeCacheSize after some time monitoring the logs.
Henning
Nice... alternatively you could use some monitoring tool that can use JMX to get this info and chart it etc. Maybe JavaMelody has it - although I don't think so.
Save the script as a file in the script path and create a service like described here: https://scriptrunner.adaptavist.com/4.3.19/jira/services.html
Or, use jobs in newer versions of ScriptRunner: https://scriptrunner.adaptavist.com/latest/jira/ScriptJobs.html
We've done this to death... check https://answers.atlassian.com/questions/145062/permgen-problems-with-scriptrunner.
You may be using another version of groovy.
If not just bump the permgen and XX:ReservedCodeCacheSize as per the question above.
