I'm running Jira 7.11.2 with codebarrel Automation for Jira 5.2.8.
I'm trying to send a web request to RocketChat in order to create channels. The RocketChat API require params for this, but Automation for Jira logs:
Error response HTTP body:
{"success":false,"error":"Param \"name\" is required"}
Error publishing webhook. Response HTTP status:
400
Automation configuration:
I've tried with smart value too: {"name":"{{issue.key.toLowerCase()}}"}.
I changed logging configuraton and added "com.codebarrel" package in order to try to see what's happening, but no lucky.
It seems like custom data not forwarded. Any help? Thanks!
After a little breath I found the solution. A mistake, actually.
I had to change the header Content-type to Content-Type and it worked. Obviously!
I am facing the same issue which you have reported here.
Headers: X-Auth-Token, X-User-Id and Content-type as application/json
Do we need to add the credentials here for the authorization ?
My problem was about word "type", where it should be "Type" (case sensitive). You did it. So it's not the same problem. I can't say if you need other heads for authorization. Maybe you should start another thread where you explain your use case for a better help. Sorry.
