Coding: How to read IQL Filter Scope from an Insight custom field?
Daz February 7, 2022 edited
Hello Community,
Using Adaptvist ScriptRunner console, trying to read the Filter Scope string that has been defined on a custom field 'Business Group' in Jira. How does one programmatically obtain this please in the Groovy lang?
The configuration screen for the custom field is given below. Its the yellow bit I want to extract.
I've got this far but dont know how to read the Filter Scope attribute
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.customfields.manager.OptionsManager
def jiraField = "Business Group"
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectsByName(jiraField as String)[0]
def config = customField.getRelevantConfig(issueObject)
PD Sheehan
April 23, 2022
I have not found a way to access the Insight custom field configuration. I tried.
I think the only remaining option is to use a sql query to do that.
Something like this if you have a jira_local resource defined in your Scriptrunner Resource tab
import com.onresolve.scriptrunner.db.DatabaseUtil
def query = '''
select issue_scope_iql
from AO_8542F1_IFJ_DCF_CONNECT
where CUSTOM_FIELD_CONFIG_ID = :configId
def iql = DatabaseUtil.withSql('jira_local'){sql->
sql.firstRow(query, [configId: config.id])[0]
or, to use pure code (less recommended)
import groovy.sql.Sql
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def query = '''
def
delegator = ComponentAccessor.getComponent(DelegatorInterface) as DelegatorInterface
def helperName = delegator.getGroupHelperName("default")
Connection conn = ConnectionFactory.getConnection(helperName)
Sql sql = new Sql(conn)
try {
def iql = sql.firstRow(query, [configId: config.id])[0]
} catch (err) {
log.error("error occurred - $err")
} finally {
sql.close()
