Colored stripe before initiative in Jira Portfolio
Jeroen Thoelen
Sometimes before an initiative the little stripe is colored for some initiatives, but why is this?
With this I mean the stripe even before the little colapse arrow.
samrobertsofficial
March 8, 2018
Hi Jeroen,
The stripe before the expand/collapse arrow is because either:
  • The issue rank has been changed in Portfolio (you may have dragged the initiative higher or lower in the list)
  • The issue was created in Portfolio, but has not been committed to Jira yet
If the initiative you mentioned doesn't have an issue key (for example it shows as PROJ, instead of PROJ-123) then the stripe is appearing because of the second reason.
When you feel comfortable with your plan you can commit your changes to Jira, and the stripe will disappear.
For more on creating issues see: https://confluence.atlassian.com/jiraportfoliocloud/creating-and-deleting-issues-828785241.html
and committing changes: https://confluence.atlassian.com/jiraportfoliocloud/committing-your-plan-changes-828785217.html
Hope this helps,
Portfolio for Jira team
