Hi @Bronagh Quinn / @Marc Jason Mutuc,
Another option is to utilise the cycle SLA option:
image2016-10-12 23:10:7.png
To set this, include the status that a request will be in when a customer response as part of the Stop functionality.
This way, when your support team responds to the customer, the SLA counter should reset. What you will then see is something like this:
image2016-10-12 23:13:4.png
The
indicates how many "cycles" a given SLA is met whenever it has started. This example shows that the SLA for Waiting for Customer has been met before.
Hope this helps!
Hey @Marc Jason Mutuc / @Bronagh Quinn,
The post-function [Service Pack for JIRA Service Desk] - Restart SLA allows you to restart the SLA timer to what it was previously. This post-function can be found in the Extension for JIRA Service Desk add-on.
Thanks for the reply Justin.
Unfortunately we are running the cloud version so do not have access to this add-on.
Hi Marc,
Did you find a solution to this? I am currently trying to implement the same scenario.
Bronagh
