Hello everybody,
Technicians forget to fill the worklog and enter only a comment in the ticket.
Best regards
This isn't something that has a technological fix. Comments are not intended to be work logs, so there's no way to do this.
Your best option is simple education, you need to find out why youre technicians are not following the process and fix that.
