Comment preview button after FEB 2019 update
Reza Seedin
Hi All,
Where has the comment preview button gone after the new update
image.png Regards
Reza
AhmadDanial
February 14, 2019
Hi, @Reza Seedin
Comment preview in the new JIRA issue view is no longer available since the new editor utilizes the WYSIWG (what you see is what you get) system and it renders the text formatting directly as you can see here:
May I know if you have any feedbacks on this new feature nevertheless? How does it work on your end so far?
Reza Seedin
Hi @AhmadDanial,
Yes, I agree the test formatting works nicely but image previews do not and are not clickable to preview to check if its the correct Image.
It was a handy feature to have.
Thanks for clarifying it
Regards
Reza
AhmadDanial
February 14, 2019
Hello, @Reza Seedin
You are most welcome. I do agree that having an attachment preview prior to saving the comment will be helpful to ensure that the right file is in place. As of now, there is no feature available to do so as the only renders the uploaded content like this:
Reza Seedin
@AhmadDanial Agreed. I was attaching a large screenshot with code but it was showing very small preview. Can I request something in the lines of a preview for images be added in the future?
AhmadDanial
February 24, 2019
Hi, @Reza Seedin
My apologies for the delayed response as I was out of office for a couple of days. Sure thing. You can definitely do that by raising a feature request in our Bug & Suggestion Tracker for visibility as well as to allow other users to vote on the request too.
I will be more than happy to help you raise one if you prefer nevertheless. Let me know which one works for you best. Thanks!
Daniel Klinkert
June 15, 2019
Hey guys,
So if I want to add a comment with a specific style such as the image below Screen Shot 2019-06-15 at 12.23.51 PM.png how can I define a custom background or style for my comment.
Thanks in advance
Tucker
August 19, 2019
Can this be undone?  The new behavior is abysmal.  If I change my mind about something or JIRA makes a bad guess, I have to fumble around with the editing bar at the top and try and find the correct option to make it right.  This exact change was the catalyst for a previous company dropping Confluence and the exact issue why two other companies I've worked with (and one I advise) to not use Confluence at all.  If this can't be configured, I'll be advising my orgs to migrate to away from Atlassian entirely.  Changes like this increase the amount of time people like me have to spend trying to write well formatted documents.
Like Piotr Cyrankiewicz likes this
Petr Maček March 21, 2022
Missing preview button makes advanced formatting very hard to use, as WYSIWG is very limited. This is pretty significant regression e.g. when using markdown.
