the issue as you see in the picture above, it doesn't render the images and the tags
Dear Ahmad Abu Saa,
Kindly, check field configuration for you project, it should be wiki style renderer.
More info you can read here:
https://confluence.atlassian.com/adminjiraserver073/configuring-renderers-861253418.html
After set wiki style renderer for field you will need reindex a project, or instance.
Gonchik Tsymzhitov
Check that Wiki renderers enabled and works properly: https://confluence.atlassian.com/adminjiraserver073/configuring-renderers-861253418.html#ConfiguringRenderers-ConfiguringaRendererPlugin
