On a same project I have two issueTypes using the same issue screen. The first issue type is used to create "templates" where you can use the "create linked issue" to create a new issue based on the first one.
Company users are asking if we can highlight the difference between the template and the issue linked. I was thinking about making a comparison between every fields from the template and the issue linked. Do you see any way to do that ?
Thanks for your help,
Regards
You would need a scripting plugin for it like Power Scripts, ScriptRunner.
Thank you for the quick reply.
This is what I was thinking of. Do you think this is the right way to do or is there another way to do it ?
If yes, any clue on how to make it ?
I was thinking of a script that would do something like :
- get the project = "my project"
- get the issueType = "my issue type" (the one to compare with the template)
- get the template linked
- get all the fields for the issueType and compare them to the ones in the template
But after I compare every values (which will already be hard I guess cause there is date, string, number, radio buttons, dropdown list, labels...) I don't know how to summarise them for the user to be able to see only what's not the same.
