Compare release versions lexicographically instead of based on release dates
Ádám Zovits January 29, 2018
Hi!
Our product is released in different major versions, which are then supplemented with additional minor releases as patches arrive while development continues along with the next major release. So as a greatly simplified release timeline we might have something like this: 1.0, 1.1, 2.0, 1.2 where after the 2.0 version was released a patch was implemented for the 1.X branch.
Now, when we execute a JQL query to collect all fixed issues for the 1.2 patch release that includes clauses like "fixVersion <= 1.2 AND fixVersion >= 1.0", the results include 2.0 even though this does not logically belong there, only because of the release date falling inbetween the release dates of the two mentioned versions.
Is there maybe a solution or a workaround for this problem? The fixVersion field does not support text based operators like "~" and creating a list of all affected versions to use with an "in" operator would be very inconvenient.
Tarun Sapra
January 29, 2018 edited
Have you tried "fixVersion in versionMatch(<regex here>)"
This seems to work, even though creating a regex to match (for example) versions 3.4.5 - 3.7.23 is still quite inconvenient, but this is at least another viable route worth considering. I'd nonetheless still prefer a way to sort lexicographically, but thank you for this suggestion!
Tarun Sapra
Possible duplicate here - https://community.atlassian.com/t5/Answers-Developer-Questions/How-would-you-find-all-numerically-greater-Fix-Versions-WITHOUT/qaq-p/558897
And similar request here - https://jira.atlassian.com/browse/JRASERVER-61828
If your request has been addresses, please accept/upvote the answer. Thanks.
Thanks to your links I have found that the comparison operators do not work based on dates as I have initially thought, but basedon the ordering of the version numbers in the "Releases" view. Which was ordered according to release dates in our installation, since new versions were simply added to the top every time.
By manually reordering the versions to the lexicographic ordering (via drag-and-drop) the initial query with the two comparisons returned the expected results.
Tarun Sapra
Yes indeed, the ordering is based on the order in the release page of the fixVersions.
Read the story
