Compatible with JIRA 6.2.2?
J Michael
January 29, 2015
Luciano Fagundes
January 29, 2015
J.M
You can check the script runner compatibility versions here:
https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner/versions
Hope it helps!
Cheers
L.F
JamieA
January 29, 2015
If following the support link from https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner it should add the plugin's tag. Maybe it was accidentally removed.
The latest released version is compatible with 6.2, for why it's not marked as compatible see https://jamieechlin.atlassian.net/wiki/display/GRV/Upgrading+to+3.0#Upgradingto3.0-MarketplaceCompatibility-isitcompatiblewithJIRA6.2?
Probably the next release would be a good time to change that.
Nic Brough -Adaptavist-
January 29, 2015
A lot of stuff is.   You'll need to tell us what you're asking about though...
J Michael
January 29, 2015
Sorry, asked through the https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner portal so assumed is was going to the vendor.
Is the Script Runner plugin compatible with JIRA 6.2.2?
January 29, 2015
Heh, yes, Jamie asks for people to ask questions in the general Atlassian area. It should have provided a label to explain what you were asking about though. There is a version of script runner for Jira 3.something-low-I-can't-remember through to 6.3 and I know he's working on 6.4 at the moment. Nip to the market place and look at the version history for the right version of the addon, or just let the UPM install the right one for you :-)
Register now
