Hello All!
I have a question regarding a User Story.
It seems that the conclusion date is inferior than the beginnign date!
Does someone knows why this is happening? I'm attaching the imagem so you can see.
Tiago
I think that the date you are showing are from BigPicture plugin and maybe someone has moved the issues in the gantt ( because data de concluao is the same date of data de Inicio) .
Or simplier, someone edit that dates
You can check in the history maybe or you can access to the gantt of your program and check it.
If you are not using the gantt you can remove those field from the screens or check with other jira admin where your project were included ( in which program of bigPicture)
