Hey all,
wanted a quick rundown on how to properly use JIRA Utilities with conditions on a workflow. I have a workflow with a transition screen from "Open" to "IN Review". There is a custom checkbox field with two options, True and False. I'm assuming I use the string comparison type. I just want to know what kind value I need to type to set the workflow to go a certain way if "True" is selected?
State 1 to 2 if checkbox = checked. Add transition condition, checkbox field != null (leave value blank) string compareState 1 to 3 if checkbox = unchecked. Add transition condition, checkbox field != null (leave value blank) string compare
