Condition on editing issue details
Daniel Juravski
I have on my issue "field1" and "field2" that were created with some values.
When I edit my issue, how can I make a condition that checks if the new value of "field1" is greater than "field2" - and only if it is , I can save my new value ?
Hope I expressed my wish well.
Mark Markov
June 28, 2018
Hello @Daniel Juravski
You cannot do it out of the box.
But you can use some plugins like Scriptrunner, PowerScripts, Jira Suite Utillities and create validator that will check your condition.
Daniel Juravski
Hi, I have those add-on's, the problem is that I don't know WHERE to write those scripts.
Mark Markov
June 28, 2018
In scriptrunner behaviour you can go to add-ons -> behaviours -> add one -> map to your project and issue type -> fields -> add field1 -> add serverside script
and script like this
if (getActionName() == null){ //check that we are on edit screen
def cf1 = getFieldByName("field1")
def cf2 = getFieldByName("field2")
if (cf1.getValue() < cf2.getValue()){
cf1.setError("field1 must be greater than field2")
else {
cf1.clearError()
Daniel Juravski
Great ! It Works ! thank you.
Mark Markov
June 28, 2018
You re welcome!
If it helps you, please mark answer as accepted :)
Prashant Mali
June 28, 2018
Hi @Daniel Juravski ,
You have to write simple script validator on transition to check values of two fields.
thanks,
Prashant
Alexey Matveev
June 28, 2018
You would need an add-on for it. For example, Power Scripts (Live Fields) or ScriptRunner (Behaviours)
Daniel Juravski
OK, but where I write that script ?
