Condition on fix version
Pierre Cattin
January 19, 2014
I am trying to use the post-function "Fast-track transition an issue" with a condition on the fix version: I only want that post function to apply to issues that don't have a specific fix version.
The problem is that I can't find how to write a condition that is false when an issue has a specific fix version. Could somebody help me to write that condition?
JamieA
January 28, 2014
This should be
"10.02" in issue.fixVersions*.name
Because... fixVersions returns a collection of Version, and the name is got by the getName() method.
Pierre Cattin
January 29, 2014
Thanks alot!
Kate McAnespie
How do you do "not in fixVersions"?
Usually this was just:
! ["version x", "version y", "version z"] in issue.fixVersions*.name
But for reason, the fast track transition fails, when the version = version a
Kate McAnespie
nevermind...figured it out.
! issue.fixVersions*.name.intersect(["version x", "version y", "version z"]) && issue.fixVersions
Deepali Bagul
Thanks @JamieA
Worked !
Mx Admin
January 19, 2014
Hi Pierre,
Have you tried issue.fixVersion != "version1"
Regards
Anand
Pierre Cattin
January 19, 2014
Thanks, but I tried that (with an "s") with the condition tester and the result is always "true", even when it should be "false". Does it work for you?
Here is what I get when I assert "issue.fixVersion=="10.02"":
JamieA
January 28, 2014
the square brackets indicate that it's a collection of some form, not a plain String.
Register now
