I am attempting to use a groovy expression as a condition on a transition post function to comment on an issue (JMWE addon).
The goal is to add a comment to an issue if either option A or B are the value for a specific field. I'm looking to see if this is possible instead of create an additional post function for option "B". The custom field is a single select drop-down.
Here is what I have so far, which works for one value:
return (issue.get("customfield_19100").find { it.getValue() == "A"} != null)
I tried a few different expressions, but none seem to work in that way.
For single-select custom fields, the test is different, as documented here: https://innovalog.atlassian.net/wiki/spaces/JMWE/pages/107413622/User+created+custom+fields#Usercreatedcustomfields-Radiobuttons/Single-selectlist
Try:
issue.get("customfield_19100") == "A" || issue.get("customfield_19100") == "B"
I am trying something very similar with two post functions but I can't get them to work consistently.
Example One Time Cost = 0, Recurring Cost = 10100, goes to done, but should go to the next approval
Post Function 1 -
Post Function 2 -
That's because the condition of post-function 1 returns true if One Time Cost = 0. Maybe you meant to write:
issue.get("One-Time Cost") <= 10000 && issue.get("Recurring Cost") <= 10000
which would make more sense as it would then be the opposite of the condition of post-function 2.
@David Fischer That makes perfect sense now that you mention it. What we actual need is the highest of the two fields value to be used.
Read the story
