Conditional formatting based on sql query result
Kfir Ratson September 2, 2014
I am using the SQL Macro to get results from a database.
What is the way to color each result based on the value returned from my query?
So for example, if I get value > 50, color the cell background in Red and if < 50, color the cell background in Green...
Eugene Domingo October 31, 2014
How would you do that?
Bob Swift
September 2, 2014
Use a case statement in your sql to distinguish the cases and apply the appropriate surrounding text. The easiest way is to use output=wiki and the color or similar macros.
