Sign up Log in
Configure Fields option in Create Screen
Krithica Gowri Shankar
The configure fields setting in the create screen has 2 options All and custom.
Can this be set to ALL by default for all users? Is this user specific like only the user can set All or custom based on his needs?
Can this be set to ALL by default  by jira admin. Also if possible please provide links to knowledge base on how to use this configure fields setting effectively.
Please help.
Krithica
Karthick Mohan April 19, 2021
The main question is still not answered. Could someone reply?
Francesc_Arbó
August 6, 2018
Hi @Krithica Gowri Shankar,
By default Jira will remember your last choice of selected fields on Create Issue screen. So, if you select all fields, Jira will remember this selection
yes I understand but for the first time when the user creates an issue will it be "All" or "Custom"?
Francesc_Arbó
August 7, 2018
By default it'll be All.
Thank you
G Krithica
benjamin.leigh
March 16, 2021
How do you set the default to all?
