Configuring Initiative field as required
mindy blossom
July 15, 2013
Hi, I have several projects setup on Jira. Can I make a subset of those projects as having the Initiative field be required?
Boris Georgiev [Appfire]
July 15, 2013
You have to
  1. Create a "Field Configuration" and set this field as required in this field configuration.
  2. Then you should associate this field configuration in a "Field Configuration Scheme"
  3. Set the new Field Configuration scheme you've created to those projects you want to have this field as required.
For more information on the topic see
https://confluence.atlassian.com/display/JIRA060/Specifying+Field+Behaviour
https://confluence.atlassian.com/display/JIRA060/Associating+Field+Behaviour+with+Issue+Types?atl_token=AG87-S37R-QM8W-6VWE%7Cf16350b82b5803d56eb8fd7a43c79f16eaaf224d%7Clin
