My Jira instance is running on a machine with IP 192.168.1.41, on port 8080 with a redirect to port 8443 (jks configured with a valid wildcard cert). This setup was tested and all was well.
Then, I introduced nginx (on a different server, 192.168.2.12) to do reverse proxy. This listens on standard SSL port (also configured with a wildcard SSL certificate). But, when I try to access the site, the "Dashboard diagnostics: Mismatched URL Hostname" error shows up and my gadgets are not displayed.
Can someone please help me configure the nginx and jira servers correctly?
Here are my current configs:
nginx:
server {
listen 443;
ssl on;
ssl_certificate /etc/ssl/certs/cert_chain.crt;
ssl_certificate_key /etc/ssl/certs/wccert.key;
server_name jira.ourdomain.com;
charset utf-8;
location /{
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass https://192.168.1.41:8443;
and, the relevant portions of server.xml in jira server:
<Connector port="8080" maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
acceptCount="100" disableUploadTimeout="true" bindOnInit="false" secure="true" scheme="https"
proxyName="jira.ourdomain.com" proxyPort="443"/>
<Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol"
maxHttpHeaderSize="8192" SSLEnabled="true"
enableLookups="false" disableUploadTimeout="true"
acceptCount="100" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLS" useBodyEncodingForURI="true"
keyAlias="tomcat" keystoreFile="/opt/atlassian/jira/certs/signedpcs12.jks" keystorePass='changeit' keystoreType="JKS" />
Base URL is setup as: https://jira.ourdomain.com
Hi there Sri,
The proxy_pass must point to 8080 port instead of 8443, here you have some information about nginx integration.
Additionally, do you have imported the certificates to the Java's true-store?, you should run this command:
<JAVA_HOME>/bin/keytool -import -alias <server_name> -keystore <JAVA_HOME>/jre/lib/security/cacerts -file youtCertificate.crt
The default password is "changeit"
Marcos.
Agreed - and I think importing cert to JIRA keystore resolves the gadget display issue too.
