×Hi All,
I would like to create a retrospective document in conclude with a table inside and allow all team member to add the comment in the table. However as there is chance of having multiple user update same time , the document update is not getting reflected.
How do we able to set up simultaneous user update option in confluence without loosing the data?
What version of Confluence are you using? 'Collaborative Editing' feature in Confluence 6 serves the same purpose.
Thanks Suhas, I am using Confluence 1000.0.0-3 , However I am not able to see the collaborative edition option in the settings.
Can we use this facility for one or selected document rather than for entire confluence space?
