Connect from Jira Plugin to SQL Server DB using JDBC
Frederik Bosler
June 7, 2019
Hi
I'm currently stuck with the following problem. I read a lot, I tried a lot but so far I still could not figure out how to solve it.
I would like to achieve the following:
  • Jira issue tab panel plugin that
  • connects via JDBC to a SQL Server instance and
  • retrieves data from a table which
  • is then displayed in the plugin
Further potentially useful information:
- JIRA Build: 7.13.0
- Application Server: Apache Tomcat/8.5.35 - Servlet API 3.1
- Java Version: 1.8.0_212 - AdoptOpenJDK
- atlassian-plugin-sdk: 8.0.7
- apache-maven: 3.5.4
- amps-dispatcher-maven-plugin: 8.0.0
The issue tab panel plugin itself already worked and I managed to display some basic data (issue and user-data) but no data from SQL was retrieved. The error message in the log was the following:
java.sql.SQLException: No suitable driver found for jdbc:sqlserver://servername\LOCAL;databaseName=dbname;user=user;password=password;
In the Jira plugin project I then I added the following dependencies in the pom.xml:
<dependency>
<groupId>com.microsoft.sqlserver</groupId>
<artifactId>mssql-jdbc</artifactId>
<version>7.0.0.jre8</version>
</dependency>
<dependency>
<groupId>com.microsoft.aad</groupId>
<artifactId>adal4j</artifactId>
<version>0.0.2</version>
</dependency>
I ran atlas-clean and afterwards atlas-debug again.
The error message I got was (with 7.0.0.jre8):
Cannot start plugin: com.atlassian.tutorial.myPlugin
[INFO] [talledLocalContainer] Unresolved constraint in bundle com.atlassian.tutorial.myPlugin [171]:
Unable to resolve 171.0: missing requirement [171.0] osgi.wiring.package; (osgi.wiring.package=com.microsoft.azure)
I partly rebuild the code of the plugin in a maven project in Eclipse and everything works fine. I am able to retrieve the data.
In Eclipse I use driver: mssql-jdbc-7.2.2.jre11.jar which is under referenced libraries. The the java code itself works.
I also tried the following (without success obviously):
  • Different sql-server jdbc driver versions (jre8 versions & jre11)
  • I also tried to add this mssql.jar the following folders:
    • \myPlugin\target\container\tomcat8x\apache-tomcat-8.5.35\lib
    • \myPlugin\target\jira\webapp\WEB-INF\lib
I read that I need to add datasources in different xml-files (e.g. dbconfig) but I am confused where exactly I now need to add which code.
If anybody has some suggestions what I could still try, I would be very happy.
For completness:
See below the class that I use to connect to SQL. This works in Eclipse. Inputs are the conncetion-string (see above) and a simple SQL-query.
public static ArrayList<Map<String, Object>> getRows(String conn, String query) throws SQLException
try (Connection con = DriverManager.getConnection(conn); Statement stmt = con.createStatement();) {
ResultSet rset = stmt.executeQuery(query);
ResultSetMetaData rsmd = rset.getMetaData();
int columncount = rsmd.getColumnCount();
ArrayList<Map<String, Object>> queryResult = new ArrayList<Map<String, Object>>();
while (rset.next()) {
Map<String, Object> row = new HashMap<String, Object>();
for (int i = 1; i <= columncount; i++) {
row.put(rsmd.getColumnName(i), rset.getObject(i));
queryResult.add(row);
con.close();
return queryResult;
// Handle any errors that may have occurred.
catch (SQLException e) {
e.printStackTrace();
return queryResult;
Deleted user March 13, 2020
May I know how did you connect to Jira and able to fetch the basic issue details?
Did you use any sql+jql driver plugin for this?
Can you please help me out if you have any idea on how to query the jira database using SQL+JQL driver
Thanks in Advance,
Bindhu
