Connecting JIRA to MySQL Using the JIRA Configuration Tool
Tshepo November 5, 2012
Hi! I am installing Jira on a windows using MySql but now i am stucked here:
On Windows:
Open a command prompt and run config.bat in the bin subdirectory of the JIRA Installation Directory.
Cant seem to run this command, its says config.bat is not recognized as an internal or external command
Tshepo November 7, 2012
Here are the logs:
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.)
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at org.apache.commons.dbcp.BasicDataSource.setLogWriter(BasicDataSource.java:1134)
at org.ofbiz.core.entity.transaction.DBCPConnectionFactory.getConnection(DBCPConnectionFactory.java:109)
at org.ofbiz.core.entity.ConnectionFactory.tryGenericConnectionSources(ConnectionFactory.java:69)
at org.ofbiz.core.entity.transaction.JNDIFactory.getConnection(JNDIFactory.java:146)
at org.ofbiz.core.entity.TransactionFactory.getConnection(TransactionFactory.java:101)
at org.ofbiz.core.entity.ConnectionFactory.getConnection(ConnectionFactory.java:59)
at com.atlassian.jira.ofbiz.DefaultOfBizConnectionFactory.getConnection(DefaultOfBizConnectionFactory.java:28)
at com.atlassian.jira.upgrade.util.UpgradeUtils.tableExists(UpgradeUtils.java:100)
at com.atlassian.jira.appconsistency.db.MinimumUpgradableVersionCheck.databaseSetup(MinimumUpgradableVersionCheck.java:49)
at com.atlassian.jira.appconsistency.db.MinimumUpgradableVersionCheck.isOk(MinimumUpgradableVersionCheck.java:30)
at com.atlassian.jira.startup.JiraDatabaseConfigChecklist.doStartupChecks(JiraDatabaseConfigChecklist.java:63)
at com.atlassian.jira.startup.JiraDatabaseConfigChecklist.startupOK(JiraDatabaseConfigChecklist.java:51)
at com.atlassian.jira.startup.DatabaseChecklistLauncher.start(DatabaseChecklistLauncher.java:35)
at com.atlassian.jira.startup.DefaultJiraLauncher$2.run(DefaultJiraLauncher.java:90)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:284)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseConfigured(DatabaseConfigurationManagerImpl.java:175)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:85)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:24)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:61)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:56)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:67)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:62)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:95) <+12> (StandardContext.java:4205) (StandardContext.java:4704) (ContainerBase.java:1053) (StandardHost.java:840) (ContainerBase.java:1053) (StandardEngine.java:463) (StandardService.java:525) (StandardServer.java:754) (Catalina.java:595) (NativeMethodAccessorImpl.java:39) (DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597) <+2> (Bootstrap.java:289) (Bootstrap.java:414)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27) <+2>
at com.mysql.jdbc.Util.handleNewInstance(Util.java:406)
at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1074)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2214)
at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:781)
at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:46) <+3> (NativeConstructorAccessorImpl.java:39) (DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:352)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:284)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556)
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
... 47 more
Jira 5.1 64bit on windows machine
Nic Brough -Adaptavist-
November 7, 2012
Hmm. What are the lines before the first communication failure? I'm trying to establish what the server was trying to do when the link-failure occurred.
For example, I know there's a bug in the xml export that means when it hits a large table you get this error, but the lines of log above it are a total giveaway - they even tell you which table it is.
Like • Boris Castagna likes this
Dnt if this will be enough info
2012-11-06 18:44:34,885 main INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2012-11-06 18:44:34,953 main INFO [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory 'C:\Program Files\Atlassian\Application Data\JIRA' is validated and locked for exclusive use by this instance.
2012-11-06 18:44:34,954 main INFO [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2012-11-06 18:44:35,186 main INFO [jira.config.database.SystemTenantDatabaseConfigurationLoader] Reading database configuration from C:\Program Files\Atlassian\Application Data\JIRA\dbconfig.xml
2012-11-06 18:44:35,288 main INFO [jira.config.database.DatabaseConfigurationManagerImpl] Now running Database Checklist Launcher
2012-11-06 18:44:38,041 main ERROR [NoModule] Error getting datasource via DBCP: JdbcDatasourceInfo{uri='jdbc:mysql://dbserver:3306/jiradb?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB', driverClassName='com.mysql.jdbc.Driver', username='jiradbuser', password='********', isolationLevel='null', connectionProperties=null, connectionPoolInfo=ConnectionPoolInfo{maxSize=20, minSize=20, initialSize=null, maxIdle=20, maxWait=30000, sleepTime=300000, lifeTime=600000, deadLockMaxWait=600000, deadLockRetryWait=10000, validationQuery='select 1', minEvictableTimeMillis=60000, timeBetweenEvictionRunsMillis=300000, poolPreparedStatements=null, testOnBorrow=null, testOnReturn=null, testWhileIdle=true, maxOpenPreparedStatements=null, numTestsPerEvictionRun=null, removeAbandonedTimeout=300, validationQueryTimeout=3, defaultCatalog=null}}
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Communications link failure
Zul NS [Atlassian]
November 7, 2012
Tshepo November 8, 2012
Thanks Zulfadi..i deleted the config file and started the setup process and everything is perfect.
Theinvisibleman
November 5, 2012
May I know which version of JIRA you are trying to install? I believe that this feature is only available starting from JIRA 4.1.
Joe
Ok..i managed to figure that with a command prompt but it gave me this message afetr testing connection:
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not recieved any packets from the server
November 7, 2012
Look through the log - that message usually means the server has not responded to a request for some reason. You need to know what the context the failure is happening in.
e.g. it's timing out because the query is taking too long, or it's able to connect, but not issue SQL the database sees as valid.
November 5, 2012
That usually means Windows can't read the file for some reason. Possibly .bat files disabled if you want obscure security settings...
Could you explain to us exactly what you're doing? e.g. in windows explorer, going to the directory and double-clicking it? Better, could you run a command prompt, cd to the bin directory and then run config.bat and tell us what the error messages you get are? Including whether they are on the command line, or if a GUI prompt pops up.
Ok, i have just installed New install of Jira on a windows..i have done the mysql setup, Java_Home correctly..i think i need to know how to access the bin directory so that i can run config.bat in the bin subdirectory.
November 5, 2012
I prefer a command prompt myself, but you should be able to use windows Explorer to find it, even if you're unfamiliar with the structure of a typical windows setup on the disk. Think back to where the installer suggested you install Jira - that's a good starting point.
Jo-Anne MacLeod
November 5, 2012
To expand a bit on what Nic said. I know that some people don't know how to use the cmd (formally called the 'dos prompt'). If you are unsure here are the commands.
Click on start and in the search bar enter: cmd
change directory to the bin directory (cd <install dir>\bin)
run the config.bat file (.\config.bat)
This will bring up pop-up. Sometimes it will hide behind your cmd window.
fill in the fields as necessary.
hope that helps a bit.
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
