Connection to Jira with jdk version 1.5
Joachim H.
September 19, 2013
I try to make a connection to Jira
My Code:
JiraRestClientFactory restClientFactory = new AsynchronousJiraRestClientFactory();
JiraRestClient restClient = restClientFactory.createWithBasicHttpAuthentication(uri, user, password);
I have the following error:
exception
javax.servlet.ServletException: Servlet execution threw an exception
root cause
java.lang.UnsupportedClassVersionError: Bad version number in .class file (unable to load class com.atlassian.jira.rest.client.api.JiraRestClientFactory)
I use these libs (and the needed dependencies):
jira-rest-java-client-api-2.0.0-m25.jar
jira-rest--java-client-core-2.0.0-m25.jar
I use in my project the jdk version 1.5. What is the required jdk version for the class 'AsynchronousJiraRestClientFactory()'?
Exists a other possibility to connect with Jira (with jdk 1.5)? I use the class 'AsynchronousJiraRestClientFactory()', because the class 'JerseyJiraRestClientFactory' ist not included (tutorial).
Pedro Cora
September 19, 2013
Currently the most recent versions of JIRA will run on JDK 1.6 and 1.7. 1.5 is no longer used, neither supported for a while already.
