Considering moving from JIRA 4.4.4 on-premise to JIRA On Demand: which, if any customizations will transfer?
Jillian Oakley Dressler
August 25, 2013
If we were to migrate from our on-premise JIRA instance (running v 4.4.4) to JIRA On Demand, would we be able to maintain our custom Issue Types, Workflows, Custom Fields etc?
LucasA
August 25, 2013
Hi Jillian,
The custom fields and workflows will be moved. However, it's important to note that, if you have any custom field, workflow statuses, workflow transitions, conditions, etc, or even issue types that has been created by 3rd party plugins, they won't work on JIRA OnDemand.
So please browse to Administration -> Plugins -> Manage Plugins (or Administration -> Add-Ons -> Manage Add-Ons) and check if all the plugins you have are listed on this page:
- Atlassian OnDemand and Add-Ons
If all the plugins you have are listed on this page, you won't lose anything when migrating for OnDemand. If you have no plugins installed on JIRA, you can also safely migrate to OnDemand.
Best regards,
Lucas Timm
August 26, 2013
Thanks! That is helpful, but we DO have some plugins that aren't listed. It's a long-standing and complex installation so it's very likely that some of those plugins are no longer needed and/or that the missing ones did NOT create elements that won't transfer to On-Demand.
Would it be possible to get access to a trial/sandbox account on On Demand so that I can test importing our data and get a better sense of what a migration plan would have to involve?
Let's build A Rovo Agent 🤖
Save your spot
