Hi All,
I want to convert a plain String to a URL(clickable link) in a vm file. I have tried using $link.encode(String) but it takes as a literal. That is , it just prints "$link.encode(String)", doesnt encode. I am not sure what do I have to enable and where in jira. Please suggest. We are using jira 6.0.8 currently which will be upgraded shortly to the latest version.
Hemanth
Hi! :)
Have you tried this one:
| ib.name | ||||||||
Escapes the characters in a
String, null if null string input</dd></dl>
Delegates the process to java.net.URLEncoder#encodeURL(String,"UTF-8"). If
then the following Velocity script:
produces this output:
Source: http://velocity.apache.org/tools/devel/generic/EscapeTool.html#url() The other option would be ( https://velocity.apache.org/tools/devel/velocity-tools-generic/apidocs/org/apache/velocity/tools/ConversionUtils.html#toURL(java.lang.String) ): toURLpublic static URL toURL(String value)<dl><dd>Converts a string to a URL. It will first try to treat the string as a File name, then a classpath resource, then finally as a literal URL. If none of these work, then this will return null.
</dd><dd><dl><dt>Parameters:</dt><dd> value - - the string to parse</dd><dt>Returns:</dt><dd>the URL form of the string or null</dd><dt>See Also:</dt><dd>File, ClassUtils.getResource(String,Object), URL</dd><dd></dd><dd></dd></dl></dd></dl> |
I'm trying the following in a macro:
$esc.url($url)
However, I just see the same output: $esc.url($url)
Any assistance would be appreciated
