Convert a field type
sasis
I would like to change a custom field from single select to multi select.It is not possible .How will i achive it
Nic Brough -Adaptavist-
August 10, 2014
You can't in the UI.
It's actually quite easy in the database though (caveats - NEVER run SQL on a Jira while it is running, and ALWAYS backup before you do this, and do a full reindex afterwards)
See https://confluence.atlassian.com/display/JIRA/Changing+Custom+Field+Types
Note that you can't go the other way, unless you're happy to lose data.
Register now
