Convert issue in a subtask : update fields
M September 18, 2014
Hi There,
I'm trying to convert an issue in a subtask with 2 customs fields, but when i convert it, in the step 3, the 2 customs fields are not displayed. I configure mandatory those fields, and only one is visible at thei step 3.A ny idea why one is missing.
Thanks for your help !
BR
Ramiro Pointis
September 18, 2014
Hi, maybe it's because you have those fields in a field scheme for the issue but not for the sub-task. Make sure you can create a new sub-tasks with those custom fields.
Ramiro Pointis
September 18, 2014
Hi Ramiro, Thanks for your answers. I can create issue with those mandatory field when i use the 'Issue Creation' Menu. But, i still have only one of those two fields displayed in the step 3 of the conversion into a subtasks. I continue to investigate Thanks
I tried with a new field, it is ok, it seems it is coming from my specific field. Is it a type of List of Multiple choices. The other type are well displayed in the step 3...
Hi, i can close this question in fact, my field has an error, i created another one with the salme caracteristic, and it works fine. anyway, thanks a lot for your help.
Register here ⬇️
