Convert sub task to task type
Tzippy Levine
I looked around and saw that I should be able to click ... and move my subtask to a task.
I see a message
N/A Change Issue Type There are no other sub-task issue types defined in the system
I am the admin of the site and I am not sure how to set up that a sub task can become a task
2 accepted
28 votes
Mihai Stumbea
April 2, 2019
I can't see a way to change sub-task to task. I'm just creating a task and then move the subtask to the new task.
Darlene Ashleigh Jeter
Here is a better picture for you provided you are using the cloud. Click the "convert to issue" and you will be able to accomplish your task.
Like • 47 people like this
Amirali Ommi
February 26, 2021
the solutions with pictures are more helpful :D
Like • 9 people like this
Sandeep Kumar
September 29, 2021
simple straight forward valuable solution.
Cyril Duchon-Doris
December 27, 2021 edited
So what am I doing/seing wrong ? I have no such button "convert to issue" and my interface is quite different from the 2019 screenshot.
EDIT : this is what Deepak Thirunavukkarasu call a "next-gen project" and you have to hit "move" and then pick subtask -> task
It seems like the JIRA team forgot to create (sub-)tasks to update the wiki when they created those "next-gen projects"... at the time of writing this doc is obsolete for next-gen projects
Like • 15 people like this
Lindsey Dengler
Indeed. This would be a value add to be able to change the issue type to a sub-task w/o having to move it. How do we vote on this?
Like • 5 people like this
Kelley Johnson
September 15, 2022
I've tried this, and I'm unable to change the "type" when I move a sub-task. In the "Change Issue Type" area, it says, "There are no other sub-task issue types associated with this project.", which seems to imply that sub-tasks can only be converted to other issue types that are still UNDER the level of tasks / stories... which kinda defeats the purpose of what I'm trying to do.
Does anyone know of any work arounds for this?Screen Shot 2022-09-15 at 5.54.48 AM.png
Like • porterk123 likes this
8 votes
Tzippy Levine
found it under the edit flow right above the list of sub tasks
Thank you
11 votes
August 24, 2020
The workaround for this in `next-gen projects` is to use the `Move` option to move the card to the same project but with a different issue type.  It worked for me.
Matt Pitman
December 2, 2021
Thank you!
3 votes
Tzippy Levine
Thank you.
The view is a little different. (I am not even sure why and I am not used to this layout)
There are 3 dots where I can move, clone configure etc. There is no option there to create or convert subtask.
To change a story to a task etc I just click on the icon next to the jira number and click change issue type. For sub task its disabled
3 votes
Victor Mutambuki
January 9, 2019
Tzippy,
Go to your ticket under MORE --> Convert to...
You can also convert a task to a sub-task the same way.
Victor
David Brad
January 13, 2020 edited
Alright, state you have task1.
You need to include some new sub tasks beneath it.
Snap on  of undertaking 1, hit 'new assignment help online beneath'. Before you type in the errand, drag it a piece to right to make it a sub task. Hit enter when done and you will get another dark sub task. Rehash.
on the off chance that you do the indent that way and, at that point hit enter it places you into another errand brief to include an undertaking at a similar degree of indent. Extremely decent. I never thought sub tasks were an issue in Todoist tbh
Jim Ryan
Hi @Victor Mutambuki
I think your solution is based on the "classic" issue view. In the "new" issue view, I can't see anywhere to convert a subtask to a task. See screenshot below. There is no "More" menu.
Can you suggest how to do this?
May 13, 2021 edited
@Jim Ryan  It is in the new view also. Did you hit the 3 buttons next to the "share" option? It should display the below (provided you have permission):
Jim Ryan
Thanks for your answer, @Darlene Ashleigh Jeter !
Unfortunately I don't seem to have that option. I'm a Site Administrator and an Admin on the project, so I don't think it's a permissions issue. (Also, I can change a subtask to a task using "Move".)
Like • 3 people like this
Levar Berry
August 23, 2021
I currently do not see a why to convert subtask into Task.
Levar Berry
August 23, 2021
AHH .. FOUND IT ..  "MOVE"
Like • 2 people like this
Sony Abigail Salazar
January 26, 2022
The option you can use to convert a sub task into a task is the "Convert to issue"
Marc Sammartano
January 18, 2023
"Convert to Issue" does not work in my environment, but "Move" does work: it allows you to "move" the Issue from Sub-task to Task.
porterk123
April 19, 2023
For JIRA 'Server' version try:
More -> Convert to Issue -> Dropdown for 'New Issue Type' -> select 'Task'
https://community.atlassian.com/t5/Jira-discussions/How-to-check-if-JIRA-is-server-or-cloud/td-p/1294469
Nicola Baker
18 hours ago
SOLVED! - none of the above worked for me.
What DID work is to use 'Convert to work item' - then you can choose the type.
It's slightly long-winded, and could be simpler but that's Jira for you *shrugs*
Hope this helps
sol solomon
March 9, 2023
The convert to subtask, task, etc works, but is very time consuming. Will there eventually be a faster way to do this? Would love to be able to drag n drop from the board. Moving sub tasks to different parents, etc.  I keep trying to do this even though I know it isn't possible.......yet.
Manasnan Lanoi
April 22, 2022 edited
The option you can see to use convert sub task to another type is on the top.
 this picture below may help you guy ;D
Register now
