Converting Kanban to Sprints
todd
I have a project that I inherited that is not set up how the team wants it to operate into the future.
Current State
I have a project that is set up with a Kanban board.  So, I have the Kanban board with its columns and also a backlog list.  When I view the backlog I see one of the columns in the Kanban board at the top of the backlog view as a group then I see a group of backlog items that have not been added to the board.  When an item is moved to a later state in the Kanban workflow, it no longer appears in either the workflow state seen on the backlog view nor in the backlog state on the backlog view.
Future State
The team still wants to move to sprints.  For an active Sprint, they want to manage it using a Kanban-style view.  But they want to be able to plan future sprints.  So, they want the backlog view to show the backlog and then groups for each planned sprint.
How do I shift from the current state to the future state?
4 votes
Petter Gonçalves
June 26, 2019
Hello Todd,
Welcome to Atlassian community!
Analyzing the description of your Future State, it seems your team is looking for a Scrum Board, where you can organize and track your teamwork based on Sprints.
In fact, you can create and plans future Sprints in a Scrum board, grouping your Stories into Sprints that are ordered by execution and having a backlog view for the not planned Stories.
In order to use the mentioned view, you can simply create a Scrum board by performing the steps below:
1 - Navigate to your current Kanban Board > Click in the board menu > Create new board:
2 - Choose the option Board from an existing project and choose the options of the client as you want
3 - Once it is created, create your Sprints as you need and map the issues according to your team progress
Additionally, you can check the differences between Kanban and Scrum in the link below:
Kanban vs. Scrum
P.S: you can switch between your current Scrum board and the inherited Kanban project by the board menu, in case you would like to compare both and configure any similarities.
Let me know if this is the option you are looking for.
todd
This is the option I am looking for.
Is there anything I need to watch for with respect to this between a "next gen" project and a traditional project?
Petter Gonçalves
June 28, 2019
Hello Todd,
The way both classic and Next-gen boards work are similar, the main difference is that Next-gen customization options are very limited, not allowing you to configure a custom board filter, Card layouts, and many other features available for the classic board.
In fact, the Next-gen template was designed for those users who felt overwhelmed by the complexity of JIRA Classic template and requested a simpler option, straight to the point with fewer options of customization.
Let me know if there is anything specific you want to know about it.
anjani_kava October 16, 2019
I have a Kanban board which I want to convert to a Sprint. Is there a way I can do that ?
Petter Gonçalves
October 17, 2019 edited
Hello @anjani_kava,
Thank you for reaching out.
Although there is not a simple button to convert a Kanban board to Scrum, can you please try the steps I provided in my first answer to Todd?
Performing those steps, you will create the exactly same board you currently have in your project with the same issues, however, using the Scrum methodology (Sprints) instead of Kanban.
That would be the easiest way to convert your project/board to Scrum.
Let me know if it works for you.
anjani_kava October 31, 2019
Thanks @Petter Gonçalves  - this worked!
Like • Petter Gonçalves likes this
Kati Driscoll June 23, 2022 edited
Veronica Caceres
November 27, 2023
Hi I do followed the steps above, but I still do not have the CTA to create sprints, is it a matter of permissions?
3 votes
Kati Driscoll July 1, 2022 edited
@Petter Gonçalves I tried following the above steps, but I don't see the Board Menu. I created a separate Jira account from my companies to test Scrum boards, etc., and I'm going to use this test account to see the process of transitioning a board from Kanban to Scrum (before I do so in our actual account).
