Sign up Log in
Copy 2 custom fields to Desciption field
Trang Vo May 17, 2018
I migrate from Mantis  to JIRA,
In Mantis I have 3 fields
Additional Information
Steps to reproduce
Description
In JIRA I want to have all these fields in Desciption
Description = (Additional Information;  Steps to reproduce; Description)
Tarun Sapra
May 17, 2018
If you are doing an import directly from Mantis then my suggestion would be to migrate these 3 fields into JIRA's description and 2 other custom fields and then later use a plugin or a script to merge the values of the newly created custom fields into description field. Once the merge is done then you can delete the 2 custom fields.
Trang Vo June 15, 2018
Thank you. Apparently I don't have another choice than that.
