Copy Issue Picker value(s) to Linked Issue Field
Richard Duffy
June 19, 2019 edited
Hi All
Goal: To limit what issue types a user can link my "Feature" issue type too.
Looking for some help, Open to all suggestions. I have scriptrunner & JSU plugins.
I have a scripted field (Issue picker searcher type) called "Link your Issue" on the create screen. The issues available are limited to JQL search.
I now need to copy this value to the Linked Issue field. I have made the field read only and pre-set the link type using a behavior. I dont mind if the value is copied on the create screen using form values or after its created using a post function.
Or I could also have a workflow validator to limit the issue types users can link too
Any help much appreciated
Richard
3 votes
PD Sheehan
June 20, 2019
Using behavior is probably the simplest here.
Add the following  server side script on your "Link your issue" field:
def linkedIssuesFld = getFieldById("issuelinks-issues")
def linkInputFld = getFieldById(getFieldChanged())
def inputIssue = linkInputFld.value
if(inputIssue){
linkedIssueFld.setFormValue(inputIssue)
Richard Duffy
Thanks for your quick reply, that works perfectly. Simple and effective!
Pawel Ogrodnik November 14, 2019
@PD Sheehan That is great, how to do it with duble issue picker, now if I Have 2 and i select second  issue picker, cleared first and write the second one.
I need 2 link
PD Sheehan
November 14, 2019
I think you can just grab the existing value first then add to it as an array.
if(inputIssue){
def linkedIssues = linkedIssueFld.formValue
if(linkedIssues instanceof String){
//if there is only one linked issue, it will be a simple String, we convert to ArrayList with the new value
linkedIssues = [linkedIssues,inputIssue]
} else {
//if there are more than one, it will already be an ArrayList, we just add to it
linkedIssues << inputIssue
linkedIssueFld.setFormValue(linkedIssues )
Like • 2 people like this
Thanks for quick answer ,
Works if it fills in the right order :)
Thanks a lot
Anuradha kumari July 29, 2020
Where need to add these script
Richard Duffy
@Anuradha kumari  these are behaviour scripts on scriptrunner for jira
Anuradha Yadav September 7, 2022
Hi, @Richard Duffy @PD Sheehan
Could you please help? I added the same script but seeing the below error.
PD Sheehan
September 7, 2022
There was a typo in the first response.
Make sure the declared variables in line 1 is spelled the same as the variable used in line 6
if(inputIssue){
linkedIssuesFld.setFormValue(inputIssue)
Hi @PD Sheehan , Yes I got that, But the filed value is not copying for me.
for Example:
  1.  my Epic 'DESP-2'
  2.  is my Feature 'DESART-3'
Now I want to Copy the value of  "STRATEGIC" field (Single Link picker) from Epic to Feature..
Needed: When STRATEGIC field is updated in EPIC the same value should be copied to STRATEGIC field in Feature and should be read-only
This is my setup in Behaviour Peter, Could you please help me here?
Oliver Schalch
Is there also a way to debug this, in the behavior settings there is nothing like "if the script was run" - i impleted on my side - but nothing happens, or the issue dont get a new linked issue from the selected issue picket issue.
Oli
