  • Community
  • Q&A
  • Jira
  • Questions
  • Copy JSD project from test environment to production without manually making all changes again in the new environment?
Sindhu
We are using JIRA_v6.4 and and JSD_v2.9,we would like to copy project from "TEST"  to "PROD" environment  with out missing any thing .
ex;
Workflows
Post functions
Conditions
Validators
Script fields
Database fields
every thing should be copied  it's like Replica"
Nic Brough -Adaptavist-
March 14, 2016
There is no easy way to do this.
You can backup everything and then use "project import" to pull in a single project, but you have to do all the configuration by hand to do that.
Have a look through the marketplace for add-ons though - I'm not aware of any that will do this as described, but there are lots that can help - Botron's project configurator add-on is the one I tend to reach for.
Sindhu
Thank you Nic for your valuable suggestion....
