Copy Value post-function not firing reliably
Steffen Neumann April 13, 2021
I have a copy value post-function in my workflow that copies the time stamp from the updated field to a dedicated custom field. It works in >90% of the cases but sometimes the field is not properly populated, which creates issues for reporting. So far, I wasn't able to identify a clear pattern when it fails, but according to user reports it mostly happens when new users from a separate in-house team are transitioning tickets.
The order of the post-functions is as follows:
- Update change history
- Re-index issue
- Fire a generic event
- Copy value
I have a suspicion that perhaps the event is not always firing as it should but I don't know how to verify or fix this.
I am on Jira Server 8.14.1
Nic Brough -Adaptavist-
April 13, 2021
It's not the event, I suspect you'll find it's the copy value function that is failing.
It probably should be above all the other functions on that list.
Thanks but when I had the copy value post-function at the beginning, it did not work at all. Since I moved it below the update event, it works most of the times but not reliably.
I am under the impression that the updated field, from which the copy value post-function takes the value, is populated by the timestamp of the update issue event.
Register today
