Copy attachment from task to linked issue during a transition
Swarna Radha
I want to copy all attachment from task to linked issue during transition. I am using script runner to create the linked issue and i want to add the attachments from the task.
Please provide me with a script.
Swarna
Sreenivasaraju P
August 19, 2019
Swarna Radha
I am getting error :
//iterate over the issues linked to the current issue through the "blocks" link type - change the link type as needed
for (Issue linkedIssue : issue.getLinkedIssues("relates to")) {
//add new attachments from linked issue
def linkedAttachments = linkedIssue.get("attachment")
for (Attachment linkedAttachment : linkedAttachments) {
//test if this attachment from the linked issue already exists on the current issue
if (!attachments.find{it.filename == linkedAttachment.filename && it.filesize == linkedAttachment.filesize && it.mimetype == linkedAttachment.mimetype})
//this attachment is new, copy it to the current issue
ComponentAccessor.attachmentManager.copyAttachment(linkedAttachment, currentUser, issue.key)
Sreenivasaraju P
August 19, 2019
Can you please let me know the error. what you are getting
Swarna Radha
Capture.PNG Please see screenshot.
Sreenivasaraju P
August 19, 2019
can you please  include below at the top and try again
Swarna Radha
Still the same
Sreenivasaraju P
August 19, 2019
import com.atlassian.jira.issue.attachment.Attachment
def linkedIssues = ComponentAccessor.issueLinkManager.getOutwardLinks(issue.id);
def attachmentManager = ComponentAccessor.getAttachmentManager();
String commentAuthor = "currentUser"
def authorUser = (commentAuthor == "currentUser") ? ComponentAccessor.jiraAuthenticationContext.loggedInUser : ComponentAccessor.userManager.getUserByName(commentAuthor)
linkedIssues.each {
def linkedIssue = it.destinationObject
attachmentManager.copyAttachments(issue, authorUser, linkedIssue.key);
try above code, it will help
Swarna Radha
I have tested the above code. No attachments are being copied.
Sreenivasaraju P
August 19, 2019
Please check whether you have add attachment permission on linked issues or not.
You can check logs for any error. or Add log statements to the code, you can find whether the issue is.
Swarna Radha
I have the permission to add attachments on linked issues. The script runs successfully.  There is no error in the logs.
Sreenivasaraju P
August 19, 2019
In this code , i am checking only outward links. can please check the links are outward or inward.
Other you can add log or system. out. println statement to check execution.
System.out.println("Current issue" + issue.getKey());
System.out.println("linked issues size " + linkedIssues.size());
linkedIssues.each {
System.out.println("linked issue >>>>" + linkedIssue.getKey());
System.out.println("done");
Swarna Radha
Time (on server): Tue Aug 20 2019 10:52:04 GMT+0400 (Gulf Standard Time)
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
No logs were found for this execution.
No logs are being found even I have changed Inwards and Outward linked
Swarna Radha
Is there any solution?
Swarna Radha
Hi, I have added logs:
Time (on server): Wed Aug 21 2019 09:51:42 GMT+0400 (Gulf Standard Time)
2019-08-21 09:51:42,719 DEBUG [workflow.ScriptWorkflowFunction]: Current issue: CM-197
2019-08-21 09:51:42,720 DEBUG [workflow.ScriptWorkflowFunction]: linked issues size : 0
The linked issues size is 0 and for linkedIssue.getKey() there is no logs.
import org.apache.log4j.Category
log.debug "Current issue: ${issue.getKey()}"
log.debug "linked issues size : ${linkedIssues.size()}"
linkedIssues.each {
log.debug "linked issue >>>>: ${linkedIssue.getKey()}"
Daphnis Hessling June 9, 2020
The reason why you get 0 for the size is because  of getOutwardLinks. Try getInwardLinks instead.
This is how we are copying the attachments from the source issue to a newly created linked issue:
import org.apache.log4j.Level
def linkedIssuesOutward = ComponentAccessor.issueLinkManager.getOutwardLinks(issue.id);
def linkedIssuesInward = ComponentAccessor.issueLinkManager.getInwardLinks(issue.id);
log.setLevel(Level.DEBUG)
log.info "Current issue: " + issue.key
log.info "linked issues outward size: " + linkedIssuesOutward.size()
log.info "linked issues inward size: " + linkedIssuesInward.size()
linkedIssuesInward.each {
def linkedIssue = it.sourceObject
log.info "linked issue >>>>: ${linkedIssue.getKey()}"
attachmentManager.copyAttachments(linkedIssue, issue.creator, issue.key);
I hope this helps.
Daphnis
Learn more
