Copy/clone a closed project
Alexandra Polisevschi
January 7, 2019
The JIRA administrators in my company chose to close all existing projects to mark the end of the fiscal year, and create new projects for 2019. I don't know details about the billing/fiscal reasons.
As a developer, this affects me, since the new projects are blank.. while the old projects had task history, progress, comments etc. Moving stories one by one from one project is not ideal.
What can be done at this point? Is there a possibility to BULK copy/clone/move all tasks from one project to another?
Do you have any recommendation for the future? I would like to propose to my company an alternative for the upcoming 2020, since using JIRA to administrate the fiscal year shouldn't affect a developer's work.
3 accepted
Alexey Matveev
January 7, 2019
You can bulk move tasks from one project to another suing the Bulk Move feature. You can find more info here:
https://confluence.atlassian.com/jiracorecloud/editing-multiple-issues-at-the-same-time-902498099.html
Ivan Tovbin
January 7, 2019 edited
Hi Alexandra,
The proper way to "close" or "archive" a project is simpy to restrict all access to it. This way you'll keep all old issues and all historical data and at the same time prevent the creation of new issues. I'd like to stress that deleting a project is NOT a good idea.
If you need to migrate some issues from and old project to the new one, then the correct approach would be indeed to bulk move your issues. If you can't do it for some reason (you might not have sufficient permissions), then you need to contact your Jira administrator so that he can do it for you.
Sreenivasaraju P
January 7, 2019
@Alexandra Polisevschi,
Assuming you are using same workflows in old and new projects. You can do bulk move of the tickets from one project to other project.
Marlene Kegel - codefortynine
If you want to bulk clone issues on Jira Cloud you can use our app Deep Clone for Jira. This could be a fitting solution if you want to keep the issues in the old projects.
Our app can clone and move up to 1000 issues in one action without losing comments, subtasks or other content.
If you have any questions or feedback don't hesitate to contact us at support@codefortynine.com.
