Copy comment to linked issue
jun lee
I added an automation rule, and it works. However when issues link relations have several steps, it doesn't work.
Issue A     comment
  ㄴ Issue B    copied comment    --> success
        ㄴ Issue C   not copied comment    --> failed
When copied comment to Issue B by an automation rule, it can't be a trigger. Audit log displays "No related issues could be found".
How can I fix it?
Florian Bonniec
March 21, 2023 edited
Hi @jun lee
You have to enable the automation to be triggered if triggered by automation, it's a checkbox to check in the automation detail where you set the owner and actor.
Be careful to make sure it will not loop.
Regards
jun lee
hi @Florian Bonniec
Thank you. It works.
