Sign up Log in
Copy customfield value from var to var.
Fabian
I hope you can help me. Maybe i misunderstood something.
I want to set a variable from type customfield with a determined customfield object. If i use getCustomFieldObject, everything works fine. But if i use getCustomFieldObjectByName or getCustomFieldObjectsByName, an error occures:
Script console script failed:
java.lang.NullPointerException
	at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:951)
	at com.atlassian.jira.issue.Issue$getCustomFieldValue$1.call(Unknown Source)
	at Script1142.addFieldValuesToOutput(Script1142.groovy:147)
	at Script1142.run(Script1142.groovy:128)
 And i dont understand, what the problem is in my script:
String sinput = "Serial Number, Assigned Group, customfield_10234"
String[] fields = sinput.split(",")
fields.each {
try {
CustomField cField = null
if (it.trim().contains("customfield")) {
cField = cfm.getCustomFieldObject(it.trim()) // If input is customfield_id
} else {
Collection<CustomField> ccf = cfm.getCustomFieldObjectsByName(it.trim()) // If input is custom field name
log.warn("CustomField: " + (ccf.getAt(0) instanceof CustomField)) // true - it is a customfield
MutableIssue issue = issueManager.getIssueObject("CSR-9588") // Test with a issue
log.warn(cfm.getCustomFieldObjectByName(it.trim())) // Works
log.warn(issue.getCustomFieldValue(cfm.getCustomFieldObjectByName(it.trim()))) // Works
cField = ccf[0] // error
// if (!ccf.empty) cField = ccf.getAt(0)
} catch(Exception e) {
Kind regards
Antoine Berry
December 20, 2021
Hello @Fabian ,
I tried your script and it is working properly, ccf[0] will return an "ImmutableCustomField". Are you sure you are using correct custom field names ?
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
