Copy field value to comment-field
Antonio D'Errico
Hello everyone,
when I comment a ticket i want that a field value will be copied additionally to this comment.
Look at the screenshot for clarification.
Best regards
Jobin Kuruvilla [Adaptavist]
January 14, 2015
You can't do that in JIRA. Maybe you can achieve it with a plugin. For example, define a variable substitution syntax and then write a listener plugin to substitute the field values after comment creation.
Antonio D'Errico
Register now
