Copy remaining estimate and then convert into hours in Calculated field
James Graham November 7, 2018
I am copying remaining estimate into another field during a workflow transition. However, the data that gets copied is in seconds. I would like to present it as hours in a calculated field. This is what I have so far:-
<!-- @@Formula:
if (issue.get("customfield_13315")==null)
return null;
return (issue.get("customfield_13315"))/3600;-->
This isn't returning any value to the field.
Please help :)
James
Nic Brough -Adaptavist-
November 7, 2018
Remaining time on an issue is not a custom field, so I suspect your "get" commands are not getting the right thing.
Unless you have defined a custom field for it, in which case, start with a look at the type of field it is.  Numeric?  Holds number of days, hours or minutes?
I am copying remaining estimate into a number field and then trying to use a custom field to convert back into hours. I can get the time in seconds but when I try to convert it into hours, I get nothing. Its quite frustrating.
James
November 7, 2018
Ok, I think it might be converting with the wrong variable types.  Could you try these two lines as calculations and see what they do (on any issue that has a number in the seconds field)
return (issue.get("customfield_13315"));
return (issue.get("customfield_13315"))/1;
I know a divide by 1 looks a bit odd, but it's a test to see if it gives you an empty result instead of the same number you get from the other line, as it would show a conversion is going wrong!
Like • James Graham likes this
James Graham November 7, 2018 edited
HI Nic,
This line: return (issue.get("customfield_13315")); Returns 10,800 (The issue has 3H remaining).
This line: return (issue.get("customfield_13315"))/1; Returns nothing and as such the field is not visible on the form view.
James
November 8, 2018
Ok, that is what I suspected then - the division is resulting in an output that does not work for loading the field.  The /1 returning a failure is consistent with that!
My guess is that there's something like a type conversion going wrong - if for example the output of a division is a float, and Jira only (usually) works with doubles and longs.
I'm not sure how you'd fix that in this scripting language.  If it were plain Java, a simple cast or explicit conversion would work fine, but I'm not sure about your scripting functionality
James Graham November 9, 2018
Thanks Nic
