Hi Team,
I need a field in Parent issue view screen like "Subtask statuses ", this should be copy all subtask statuses.
Can you help me the right code ?
Nagaraju
Hi Team,
Can anyone help me on coding how to achieve this.
Hello @Musku Nagaraju
When you say - "this should be copy all subtask statuses" , do you mean the field should have the currently statuses of all the sub-tasks?
And if that's the case then you can have a scripted text field which can contain comma separated aggregation of the statuses of all the sub-tasks
If the scripted field you just need to fetch the subtaskObjects and aggregated and return their statuses which should be pretty straight-forward.
There are plenty of script runner examples available on this portal for scripted fields. And also in the ScriptRunner documentation.
