Copy system field "Due" to CustomField
Jonas Andersson
September 4, 2017 edited
Hi guys,
I see hundreds of examples of copying custom fields to other customfields, but how do i copy System field ("Due") to a custom field in all issues matching a JQL?
I am using a snippet found on the community that looks like this:
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.issue.index.IssueIndexManager
import com.atlassian.jira.util.ImportUtils
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser.class)
def searchProvider = ComponentAccessor.getComponent(SearchProvider.class)
def issueManager = ComponentAccessor.getIssueManager()
def indexManager = ComponentAccessor.getComponent(IssueIndexManager)
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def query = jqlQueryParser.parseQuery("project = ATP and due is not EMPTY") // change query to match the issues you want to update
def results = searchProvider.search(query, user, PagerFilter.getUnlimitedFilter()) // get results of query
results.getIssues().each {documentIssue -> // go through each issue
    log.debug(documentIssue.key)
    def issue = issueManager.getIssueObject(documentIssue.id)
    def customField = customFieldManager.getCustomFieldObjectByName("Start date");
//    System.out.println(customField)
    customField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(customField), documentIssue.key),new DefaultIssueChangeHolder()); // update values
List issues = results.getIssues();
for (Issue issue in issues) {
    boolean wasIndexing = ImportUtils.isIndexIssues();
    ImportUtils.setIndexIssues(true);
    indexManager.reIndex(issueManager.getIssue(issue.id));
    ImportUtils.setIndexIssues(wasIndexing);
But i am unable to specify the Due field using this example.. Could someone help me out?
Nic Brough -Adaptavist-
September 4, 2017
issue.getDueDate returns a "time stamp" object which can go straight into the custom field's modified value.
Jonas Andersson
Jonas Andersson
Jonas Andersson
September 4, 2017
Needless to say, As usual you kick ass. Got it working just fine! Thanks mate!!
Jonas Andersson
September 4, 2017
I should mention that Due field seems to be a string with the text like "2012-01-24" which will go into a custom field that uses date encoding (which follows the exact same format, except for the string vs date type declaration).
Harsh
December 5, 2022
Hey, can you share the final snippet here, I am unable to do the same. I need to copy due date values to custom field.
Lars Swart
January 13, 2023
Hey @Harsh  did you find a working solution. I'm also interested in it.
Harsh
January 17, 2023
Hi @Lars Swart I did using the Automation. If it works for you.
