Copy system field values to custom in bulk?
TSD Group June 20, 2016
There is a built-in script which allows to copy custom field values from one field to another in bulk. Is there the same possibility to copy values from system field to custom? E.g. from Due to DateCustomField ?
Vasiliy Zverev
June 20, 2016
Here is a code example:
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.project.Project
 * Move date value from one custom field to another
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField dateFrom = customFieldManager.getCustomFieldObjectByName("field name 1");
if(dateFrom == null)
    return "field for date from not found"
CustomField dateTo = customFieldManager.getCustomFieldObjectByName("field name 2");
//Loop issues and update
IssueManager issueManager = ComponentAccessor.getIssueManager();
for(Project project: ComponentAccessor.getProjectManager().getProjectObjects())
    for(MutableIssue issue: issueManager.getIssueObjects( issueManager.getIssueIdsForProject())){
        issue.setCustomFieldValue(dateTo, issue.getCustomFieldValue(dateFrom))
        issue.setCustomFieldValue(dateTo, issue.getDueDate()) //if you want to copy from due
        issueManager.updateIssue(ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser(), issue, EventDispatchOption.ISSUE_UPDATED, false)
TSD Group June 28, 2016
Hi Vasiliy,
Thank you for the answer! Sorry I am late with my reply.
Do I need to copy your example of a code, then paste it into the Script Console and click the Run button?
I just never did this operation.
With kind regards
Vyacheslav
Vasiliy Zverev
June 28, 2016
  1. Test it on test JIRA instance.
  2. Yes, you need just to cope it to a script console
  3. Try also to perfom it at first not on all project/issues, but only on sigle peoject/issue
  4. Good luck!
I see you are novice, since ask more questions here.
Help us plant more trees
