×Hi,
We have a list of tickets already created - from that list, a support guy goes into every ticket and uses the option "Create Linked Issue" to create new tickets for the same project but in a different issue type - of course, linked to the original.
Now I have a custom field called "additional details" that exists in the original ticket, and i want to copy the content of that field into the description field of the linked ticket the support guy is creating.
I tried automation for Jira, but it simply doesn't work. I have something like this:
Trigger: When a new issue is created
If Issue Type equals "Task"
And "Linked Issue Present"
Then Edit "Description" from Parent Issue => Field to copy the value from "Additional details".
In my mind this logic is right, but it doesn't work.
The question: How can i copy a custom field value from a linked issue into the description field?
Hi @Albert Manuel ,
Hope you are doing well.
Here's an automation rule that I configured that might help your case:
Trigger: When you navigate to ISSUE-A and link it to ISSUE-B from there.
Once you set up your trigger,
Click Add component > New branch > Branch rule / related issues > Current issue
Action: Copy the value of the custom text field 'latest comment' from ISSUE-A and paste it into the description of ISSUE-B
Thank you,
Bhanu :)
Hi @Bhanu KN
Having Jira data center here, but it;s not that different. The point is your automation rules work, but the other way around. I mean it takes the description i use when i create the linked issue and it updates the parent also. I need the description from the parent to be copied to the new linked issue that is created.
Check my automation rule.
Hi @Albert Manuel ,
It worked as I explained in the cloud though. Can you try switching? Instead of 'for current issue', use 'for destination issue' and copy the value from 'current issue'.
